Soo someone told me that I should spend more on my GPU and go Cheap on my CPU if I’m looking to be gaming. Ofc to reduce bottleneck.  For my build I’m looking to game at 1440p high fps.
Now I’m in this predicament because I don’t know which one to go cheaper on Should I chose a cheaper CPU instead of my Ryzen 5600 that I wanted to get? Or should I go cheaper on my GPU instead of my RX 5600XT I wanted to get.
And if you think I should go cheaper on one of them and go bigger on the other let me know which ones to use instead.
  • My Budget for both parts in total is $365 USD
Someone please explain this to me and suggest some ideas thanks!
https://linustechtips.com/topic/1177360-i-need-some-help-plz/
Definitely don't skimp on CPU, getting a quality CPU now means you can always upgrade your graphics card in the future. I'd say go cheaper and/or buy used on the card instead to save money (especially because, contrary to popular belief, graphics cards do not wear like other components).
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/1177360-i-need-some-help-plz/#findComment-13476594
depends, what performance target are you hoping to reach, and in what games?
The Ryzen 5 2600 is far from a bad CPU, and if you are buying in an asian market, the Ryzen 5 3500 is also an option.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1177360-i-need-some-help-plz/#findComment-13476614
So can you tell me what should I do them like should I get a higher priced CPU? And a lower priced GPU?
https://linustechtips.com/topic/1177360-i-need-some-help-plz/#findComment-13476639
I’m looking to perform in high frames my dude at 1440p In games like GTA or Overwatch.
https://linustechtips.com/topic/1177360-i-need-some-help-plz/#findComment-13476643
Overwatch can get some great frames on the Ryzen 5 2600, and so can GTA. Since you're targeting 1440p, don't skimp on the GPU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177360-i-need-some-help-plz/#findComment-13476657
Can u reply pls
https://linustechtips.com/topic/1177360-i-need-some-help-plz/#findComment-13476966
1 minute ago, OreoShake said:
What GPU would you recommend if I get the 2600 then
The 5600 XT that you mentioned earlier, if that was what you were trying to save money for.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177360-i-need-some-help-plz/#findComment-13476980
