Are you running stock settings? I've got H115i Pro with my 3700X and I've got idle temps hanging around 40c and under load depending on the load 65-77c. I made a mistake in installing the fans the wrong way around at first and the temps were much higher so maybe it's worth checking out.
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13473978
Just running it with PBO. Top fans are exhaust and i have bottom fans for intake.
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13473982
I have my 3700x overclocked to 4.2ghz, and am using a Fractal s36 which is also a triple rad AiO, and right now at idle the temps are hovering around $35.
I just did 2 back to back Cinebench r20 tests to heat things up, and about 72c is the hottest I'm getting. So yours is probably as expected, your ambient temp (of the room) and air flow can influence things, also is there an overclock?
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13473995
Another thing I want to note is it could be your cpu voltage that's causing the extra heat. Left to auto, Ryzen wants to run around 1.45 volts, 1.5 being the furthest you'd ever wanna go. With my overclock I have the voltage set to 1.33 or 1.35 (don't remember which) but that could be why my temps are a little under yours.
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474001
Oh yeah the auto voltages are probably the reason. I have set my voltage to 1.2V which dropped the temperatures down quite a lot.
one thing I found is there's a bit of a sweet spot. Like, I could have my voltage set to a solid 1.3 or a little lower, and even though it shows I'm still hitting the 4.2ghz mark, my scores on things like cinebench r20 will be around 4400, but when I raised the voltage a bit more to around 1.35 I was still able to lower temps some and I hit a higher score around 4800, even around 4900.
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474019
Temps drop quickly when manually setting voltage to 1.35. For overclocking to 4.2 have you just set the voltage and changed each core to 4.2? Also when using PBO it says the peak voltage is 1.35 but goes over
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474025
the voltage will always go a small amount over whatever you set it to. I don't think I'm using PBO, I just have a manual override of 42 to the core ratio. That and the 1.35 volts
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474033
3rd gen Ryzen doesn't really OC well to begin with, nor does it yield much performance gained, fast RAM and adjusting PBO settings in Ryzen Master is best if you want to ‘OC’.
3rd gen Ryzen CPU's seem to show faster degradation symptoms if higher voltages are applied (something I recently learned). For long term 'safe' OC'ing voltages below 1.375V were considered to be fine. However, this rule of thumb is adopted from overclocking Intel CPU's, and previous generations of AMD CPU's.
So, for long term use I would NOT recommend OC'ing via the standard Manual method in Bios. Keeping the voltage low (1.27500V or lower w/ a manual offset if you want to play around more) and adjusting PBO settings is the safest way to squeeze out some extra performance. But even then, only expect 100-300MHz at most.
Good read on voltage issues with the new Ryzen CPU’s: (And why I recommend low voltage)
https://www.reddit.com/r/overclocking/comments/ejd5c9/1325v_is_not_safe_for_zen_2/
All this info comes from tirelessly scouring many many resources and doing lots of research after learning of the high voltage issues with 3rd gen Ryzen.
Those high temps are definitely because of the high voltages. 1.2V is safe. What motherboard do you have?
With my Asus Crosshair VII Hero by default my voltages were all over the place.
I adjusted as follows:
-          CPU Core Voltage – Manaul Mode – 1.2500V
-          CPU SOC Voltage – Manual Mode – VDDSOC 1.1000V
-          DRAM Voltage – 1.3500V
-          1.8V PLL Voltage – 1.8000V
-          1.05V SB Voltage – 1.0500V
The best performance squeeze is your RAM, I set my Corsair Vengeance 32GB 3200MHz CL16 to 3400MHz at 1.3500V and tightened up my timings, that has given me the best performance results. I would start at your RAM’s rated speed and go from there.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474051
I have an X570 Taichi. I can't change the voltage in ryzen master when using PBO. I found that setting an OC of 4100 and voltage at 3.2 has given me lower temps and better results. (Quick cinebench tests).
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474095
Are you using the Ryzen balanced power plan? I have a 3900x cooled by an H110i and at idle I run from 29-40c with an occasional spike. Voltage reads from .360-1.15 volts at idle. What I would suggest is to go to AMDs website and download the chipset drivers direct from them. Once installed you should get access to the Ryzen power plan.
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474214
I am using power plan.
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13474382
I am referring to adjusting voltages in bios.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13476788
On 4/13/2020 at 3:44 AM, DylanJM_ said:
Idle temp 45-55
Under load temp avg 75 max 79. Using corsair h150i pro
Is this normal?
Idk why my 3700X is also having those temps even with custom loop even at 4.2GHz all cores with only 1.225v, and use balance power plan.
Tried to remounted the CPU block with as much mounting pressure as I can, nothing change.
It have reached 84C only at 1.224v with less than 90W full load while my GPU maxed at 69C/1.2v/218W in the same load operation in same loop.
There is far gap between the GPU vs CPU while the GPU draws more than twice the CPU power while maxing at 15C lower than CPU. Why like this?
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
https://linustechtips.com/topic/1176985-3700x-temps/#findComment-13478242
