Need help with PSU
Go to solution Solved by MrBrightSyde,
The Core GM is Tier B+ on the PSU list so I would go with that.
Hi new guy here, recently i was searching for a new psu for my pc and i saw a Seasonic Core GM that caught my eye.
I know nothing about Seasonic (Until some time ago, i was just buying any psu that seamed good enough and cheap without researching) and i found no review for it, does anyone here have some experience with it?
Thank you very much!
https://linustechtips.com/topic/1176632-need-help-with-psu/
ive never had a seasonic, but theyre apparently really good
Either @piratemonkey or quote me when responding to me
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471493
Thanks for all the answers!
17 minutes ago, Daniel Z. said:
Seasonics are all decent-great.
Yeah, almost everyone says that for Seasonic on the internet, but almost no one talks about this particular model (Core GM)
6 minutes ago, seon123 said:
Seems to likely be a lower end Focus. I would suggest looking at other options, as Seasonic outsources a bunch, cheaps out on the fan and protections, even on their highest end PSUs.
I don't have many options here (not from the US) so my options are very limited, the other brand is Thermaltake
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471529
i would not recommend you go with thermaltake. i've never heard of a good thing from them. if you can only go with two go with seasonic. if nothing else and it breaks, you got warranty for years. if you can, i would go for a corsair or evga. both are quality. i have the evga gold 750w something or other, and its nice
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471546
The only EVGA it's the N1 400W model that people seem to not like at all (and i don't know if 400W is enough to support my system), so i guess i'll go with the seasonic one.
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471560
7 minutes ago, seon123 said:
Well, where are you buying from?
A store in my country, there aren't many that sell non generic psu.
The psu in my price range are the evga N1 that i mentioned above, a seasonic S12III (read bad things about that one) and the Seasonic Core GM, the thermaltake ones are more expensive and are 700W+ which i don't think i need.
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471605
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471747
19 minutes ago, TwilightLink said:
I saw that list, but i didn't saw the Core GM, is it the Core Gold?
Yes. Its in temporary position there if you noticed (italics) because the info on it's performance is limited but depending on the price it could be decent choice, certainly better than EVGA N1.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471843
Yeah, i couldn't find much info online, i'm probably going to get it then, seeing that my current psu is tier E in that list,
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471875
Really? I don't see any italics on the Core Gold.
In any case, it's better than OP's current PSU apparently since his current is Tier E
MAIN PC:
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471885
I was very surprised by that, i've been using it since like 5 years.
But anyway, thanks all for the answers, i'm buying the Core GM as soon as i can.
https://linustechtips.com/topic/1176632-need-help-with-psu/#findComment-13471911
