2560 x 1440 IPS 144hz Help!!
Tormund
So while i'm stuck at home, i've been playing more COD and CSGO, I feel like need a 1440p 144hz panel to keep up but all best ips monitor's seem to be nonexistent like the LG 27GL850. Is there anyone who can point me in the direction of this monitor or give any first hand experience on a suitable alternative, also i'm residing in the U.K, thanks in advance for any info given.
I don't personally have any first hand experience with this, since I'm using a 60Hz 1440p IPS panel, but I'd check these rtings.com for some very detailed reviews where you should also find some more alternatives.
I'd check these links here for some recommendations:
https://www.rtings.com/monitor/reviews/best/by-usage/gaming
https://www.rtings.com/monitor/reviews/best/1440p-gaming-monitors
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
