I have been planning to upgrade some of the components in my PC since many people said that my GPU is the performance killer. Instead of just upgrading the GPU , I will be upgrading the RAM to have at least 16GB of RAM (having 7 gigs is just strange lol). I have been thinking of a GTX 1650 4G OC MINI (it consumes about the same as my 750ti , around 75 watts) , now I've thought about an RX570 or RX580 which are better cards for wayy less money BUT there are two problems:
1) The space in my case , I can't just put in a dual fan gpu. I can put in a Single fan or low profile cards.
2) The PSU is just a 320w HP power supply which I can't change since it has proprietary connections, and the RX570 and 580 recommends at least a 400-500w psu.
What do you guys think?
My Current specs:
i7-2600
GTX 750Ti 2GB
7GB RAM
https://linustechtips.com/topic/1175759-sandy-bridge-system-gpu-upgrade/
Not all prebuilts are built the same, some can't reliably provide the required 75w through the PCIe slot itself. So I'd tread cautiously, installing a GTX 1650 even though it doesn't need an external PCIe power connector may still damage that motherboard or power supply.
Edit: nevermind, if it's powering a 750 ti it'll power a 1650, you should be fine
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Yeah I've been using this card since August when I bought it and I even overclocked it without any problems.
Most if not all prebuilts with proprietary psu connectors have some kind of a adaptor that you can use, especially those from well known manufacturers like dell and HP
1 minute ago, WikiForce said:
if a 750 ti is fine then so should be a 1650, only 15w of difference.
that cpu is powerful enough to handle upto a 1060 6gb, though considering your psu is a limiting factor i would recommend getting a 1650 would be a safe bet. Also, you can use a normal psu as there are adapters easily available for 24pin to proprietary motherboard power connector.
I know, edited my reply.
Well, you could also upgrade your power supply and get an RX 5700 xt.
But it's still a 320 watt sketch-ass prebuilt PSU that already has an i7 2600 hooked up to it... Sure if you want to kill OP and burn his house down, use the adapter, but unless he upgrades his power supply, the safe bet is to stick with the 1650. It's going to be a huge upgrade anyway, I believe it's ~60% faster
What I meant is that he could buy a adaptor for his motherboard with proprietary power connectors so he could install a standard 500W psu that suits his needs.
