Ryzen 3600 help please
Solved by bellabichon,
Unfortunately, if your system is running fine with another CPU installed, that's most likely an issue with your 3600. I would try reaching out to AMD to see if there's any more troubleshooting steps you can take that you haven't tried yet. If you're convinced that your CPU is broken, you can try applying for warranty service on AMD's website.
