Why are you getting the 4770k?
Do you do a lot of editing?
Seems a little unbalanced. I'd go 4670k, sell your card and buy a better graphics card.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/117527-upgrade-help/#findComment-1568467
Hey I wanna get the 4770k because in the future I plan on doing alot of video editing and possibly even benchmarking and would crossfire be worth it because I really don;t have the money to get something like a 770 or 780 which is what I would get if I were to go with something other than the two 7770's.
https://linustechtips.com/topic/117527-upgrade-help/#findComment-1568484
What about going AMD? You'd save a lot of money there and I believe they're still decent.
I wouldn't bother spending the money to Crossfire 7770's. Can your power supply handle the extra load? If not that's another added cost.
I'd sell your 7770, and use the money you had for the other 7770 to buy a 270x. It destroys a single 7770, and uses way less power than dual 7770's with a lot less issues.
https://linustechtips.com/topic/117527-upgrade-help/#findComment-1568520
Okay so I definently don;t want to go amd for cpu just because of the things I want to do in the future and i'm sure my power supply could handle it also what would you reccomend for graphics if I didn;t go two 7770's
https://linustechtips.com/topic/117527-upgrade-help/#findComment-1568670
270x like I said. ;)
What power supply do you have?
How far in the future are we talking?
https://linustechtips.com/topic/117527-upgrade-help/#findComment-1568792
