Hello my name is jhon,
Basically i need help on what bitrate  as well what preset, profile, and max B frames i should put on OBS?
this all new to me, i came here because im a fan of Linus videos so maybe someone could help me learn how obs works so i can put a great stream.
sorry im nub.
https://linustechtips.com/topic/1174667-help-on-streaming/
For live streaming on twitch at 720p60 a bitrate of 6000 should be ok, and the max B frames is usually set to 2.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1174667-help-on-streaming/#findComment-13455579
11 minutes ago, jhon101 said:
thank you so much for replying, Im trying to stream on mixer but everything still apply. my download speed is 192 and my upload speed is 11.80.
You should be ok, I think depending on the video quality, 3-6Mbps or better for the upload speed is recommended.
System specs below
PSU: Corsair CX650M
https://linustechtips.com/topic/1174667-help-on-streaming/#findComment-13455660
https://stream.twitch.tv/
Please post your system specs. For 720p30 2500-3000kbps is good bitrate. With your upload, you can go up to 5000kbps, thats 1080p30 or 720p60. But you also need CPU power to encode that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1174667-help-on-streaming/#findComment-13456918
