Hi, new here to LTT Forum. I'm finally upgrading my mid 2011, 27" Imac. Yes, It's the one with the crap video card. I'm going to upgrade to Nvidia geforce gtx880m. When I opened It up WOW!!! I'm surprised It didn't burn up from all the dirt and dust. I went and got some CRC QD electronic cleaner. Before I start going to town spraying all the parts. I want to know do you think It's safe? Air alone wont do It and, yes I removed every part from the Imac. Thanks for any help.
https://linustechtips.com/topic/1174588-imac-cleaning/
Air will be plenty. Just because there is dust on stuff won't hurt it. Make sure you get the big stuff out, clean the heat sinks and whatnot. You don't have to scrub everything down though.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/1174588-imac-cleaning/#findComment-13454869
That cleaner will be fine, it’s just an alchohol based cleaner, so you shouldn’t have any problems. maybe re apply thermal paste while your at it? Will make it quieter and cooler
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1174588-imac-cleaning/#findComment-13455142
Agreed. Maybe want to grab a toothbrush too to get in the nooks and crannies.
https://linustechtips.com/topic/1174588-imac-cleaning/#findComment-13455262
Tooth brush works great for heat sink fins.
AMD blackout rig
https://linustechtips.com/topic/1174588-imac-cleaning/#findComment-13455289
I think you’ll have too use special iBlower, just £999 😂
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1174588-imac-cleaning/#findComment-13460236
