Hi, I am planning on building a PC for game development, 3D modeling, and programming.
Here is my list so far :
I need the build to have Wifi and needs to be around $770. I live in the US, if that helps.
What do you guys think? Thanks for checking out my post!
https://linustechtips.com/topic/1174554-need-help-planning/
The motherboard is way overkill for the CPU you have. You could save an easy $100 and get a MSI B450 Tomahawk instead. Then you could also use the extra money to get a larger SSD if you wanted. Otherwise everything looks good.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
https://linustechtips.com/topic/1174554-need-help-planning/#findComment-13454597
Thanks for responding! The MSI B450 Tomahawk does not have Wifi, and I need it to have Wifi because my parents do not have wired internet in the house.
Is there anything else I could do to improve this plan?
https://linustechtips.com/topic/1174554-need-help-planning/#findComment-13454613
https://linustechtips.com/topic/1174554-need-help-planning/#findComment-13454618
Buy a USB WiFi or internal WiFi adapter. They're only $25-35, so you'd still be saving at least $50.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
https://linustechtips.com/topic/1174554-need-help-planning/#findComment-13454619
11 minutes ago, Daniel Z. said:
Thanks for helping! I will definitely change my parts list!
https://linustechtips.com/topic/1174554-need-help-planning/#findComment-13454674
