Hello guys... I'm new here.. so I need some help about my system... first of all... I'm sorry for my bad english... hope somebody can understand..
i have a problem with my FPS here... i don't know where the problem was start. Here is my rig imformation
CPU: Intel i5 6400
Motherboard: Asus B150 pro gaming
RAM: Kingston hyperX 24gb
GPU: Asus Strix GTX1080Ti 11gb
PSU: Hu Meng 1650w 90+Gold
240gb SSD for OS W10
1T HDD for storage
AOC e27" LED..(non 4K)
Before, I was run this system with Asus GTX950 and with Corsair 550w PSU. All game i have play just reach 60/61fps max. (Metro exodus, NFS Payback, Battlefield 1 and much more 2015-2019 game. Some game use max high setting and some ultra. So... i just change the GPU to 1080 Ti.. but sadly.. the FPS still same.. then i think the PSU is not enough power.. so change to 1650w PSU... and its still same.. max 60/61fps. So guys... will somebody help me find out what the actually problems here... for my knowladge level.. I stuck.. cant thinking anymore... what i think now... should be I upgrade the motherboard and CPU.... or... is that my GPU problem itself?? Thanks all.
https://linustechtips.com/topic/1173761-low-frame-rate/
have your capped your fps to 60?. disable vsync/freesync in games.
it can be your cpu bottlenecking too.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1173761-low-frame-rate/#findComment-13448443
7 minutes ago, Haili5450 said:
I dont do any capped... other imformation.. i'm just play offline. Since i buld this sytem with GTX950.. im just plug n play, just auto setting high or ultra... no costume setting. So... should I disable or enable the vsync/freesync?
It's a bottle neck your cpu is bottlenecking the GPU try selling it and getting like a r7 2700x for like 230ish to 250 bucks
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1173761-low-frame-rate/#findComment-13448496
43 minutes ago, Avocheeseado said:
i5 9600K
why buy such a terrible value cpu when you can get a 2700x for almost the same price
Build Log:
https://linustechtips.com/topic/1173761-low-frame-rate/#findComment-13449311
