Hey everybody
I'm thinking on getting the eluktronics Mag 15 without an SSD and RAM.
I couldn't find their motherboard specifications (I asked their support but they didn't answer)
Anyways, if you know what's the fastest RAM and SSD I could  buy which the motherboard will support.
For example I wanted to buy Sabrent Rocket Gen4  M. 2 PCIe NVMe SSDs but I don't know if my Pcie is a 4 gen or not (otherwise it won't support it)
I'm not limited by budget
Thanks
https://linustechtips.com/topic/1173602-eluktronics-mag-15/
2 minutes ago, repmel007 said:
Hey everybody
Thanks
it is intel so max 3rd gen pci and spend the extra money a more storrage or laptop with better gpu
https://linustechtips.com/topic/1173602-eluktronics-mag-15/#findComment-13447216
