So, i wanted today to use DDU so i can reset my gpu driver since i upgraded and when i changed it i forgot to.So after i went in safe mode and clicked The Restart option which restarts your pc after it removes the driver i was stuck in the restart loop. It just didn't want to restart, so i held my power button closing the pc forcefully.After that it booted fine reinstalled the drivers, and checked to see if the restart button is broken. To my surprise it worked just fine i restarted 2 times and it worked both times.Im just wondering could i have messed something up with that? Like damage my gpu or cpu or something?
馃挔Case: SilentiumPC Signum SG7V EVO TG ARGB
馃挔Processor: AMD Ryzen 9 5900x
馃挔Graphics Card: ASUS TUF RTX 4070 OC
馃挔RAM: 32 GB Corsair Vengeance RGB PRO @ 3600 CL18
馃挔CPU Cooler:NZXT KRAKEN Z73
馃挔Power Supply: Corsair CX750 (750W)
馃挔HDD: 1 TB WD Blue
馃挔SSD 1: 240GB Kingston A400
馃挔SSD 2: 960GB Kingston A400
馃挔Motherboard: ASUS TUF B450M PLUS GAMING
https://linustechtips.com/topic/1173455-ddu-problem/
I had a similar experience when I last used DDU and I haven't had any problems yet so it should be fine.
https://linustechtips.com/topic/1173455-ddu-problem/#findComment-13445809
How long ago did it happen?
馃挔HDD: 1 TB WD Blue
https://linustechtips.com/topic/1173455-ddu-problem/#findComment-13445857
Just now, Mr. PC said:
Almost a year ago
And you we鈥檙e stuck on the restarting screen?
馃挔HDD: 1 TB WD Blue
https://linustechtips.com/topic/1173455-ddu-problem/#findComment-13445863
1 minute ago, Mr. PC said:
Until I had to switch of my psu.
Can something bad realistically come out of this happening?
馃挔HDD: 1 TB WD Blue
https://linustechtips.com/topic/1173455-ddu-problem/#findComment-13445872
