-> Moved to New Builds and Planning
The question is impossible to answer unless you give us more details. Like what you will be doing with this. Also, usually better to ask before buying than after buying. That way any changes will be easier to do.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1172943-will-i-bottle-neck/#findComment-13442113
I will be using it for gaming
https://linustechtips.com/topic/1172943-will-i-bottle-neck/#findComment-13442230
Yeah, that doesn't really help to say thing to either direction. What games, what resolution? You have i3, so anything CPU heavy will be nope.
https://linustechtips.com/topic/1172943-will-i-bottle-neck/#findComment-13442238
