As long as you have the right firmware for the model you won't brick it.
You can also try custom firmware for that phone.
https://www.sammobile.com/samsung/galaxy-s8/firmware/SM-G950U1/ATT/
https://linustechtips.com/topic/1172906-software-help/#findComment-13441597
