Here is whats happening to my pc. BSoD, lockup/freezing then monitor turns off but pc fans and lights are still on.
I first encountered it when i just tried to stream while playing. It didn't bother me. I just thought it might be my slight overclocked wasnt stable so i just revert my bios settings to default.
But after that my pc still keeps crashing at random moments.
This are the moments when my pc crash.
  • while playing games. (this happened in league of legends, call of duty warzone, world war z, lurk in the dark: prologue (this was the game i was streaming when it first crashed) and bayoneta these are the games that i am currently playing )
  • when a game is done and i return to lobby/client (this happened in league of legends and world war z)
  • while playing a video in youtube, and sometimes just clicking play or resuming a video.
  • sometimes it crashes when i just click on something
These are the thing i tried so far.
  • reseating everything on the mobo except for my cpu
  • using ddu and installing previous drivers
  • reinstalling windows without wiping my D: drive (only wiped my C: drive)
  • reinstalling an older version of window with the iso file i used last year because i only encountered this after updating to 1909
  • moving ram stick to other slots
  • moving hdd sata cable to other slots
  • memtest 86 finished it without errors
  • running furmark for 15mins ( i know its a short time but i saw someone said if it can run furmark after 10mins its fine)
  • tried updating mobo bios and reverting to a previous version
PC SPECS:
Mobo: Asrock AB350m PRO 4 currently on bios version 5.80 (tried bios versions 5.90 and 6.00)
CPU: Ryzen 5 2600
GPU: Gigabyte gtx 1070 8gb
RAM: 8gbx1 Hyper x 2400mhz
HDD: 1TB Seagate Barracuda
1.
Problem signature
Problem Event Name: BlueScreen
Code: 1e
Parameter 1: ffffffffc0000005
Parameter 2: fffff8025de9412c
Parameter 3: 0
Parameter 4: ffffffffffffffff
OS version: 10_0_18362
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.18362.2.0.0.256.48
Locale ID: 13321
2.
- The computer has rebooted from a bugcheck. The bugcheck was: 0x0000001e (0xffffffffc0000005, 0xfffff8025de9412c, 0x0000000000000000, 0xffffffffffffffff). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 0ef8cd1f-5cb1-448d-a0f2-91cf687ce35a.
3.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Fri 03/04/2020 4:23:07 am your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\040320-18140-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1BC810)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF80332A9412C, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Fri 03/04/2020 3:47:02 pm your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!KeRegisterNmiCallback+0x1EE)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF8025DE9412C, 0x0, 0xFFFFFFFFFFFFFFFF)
The following dump files were found but could not be read. These files may be corrupted:
C:\Windows\Minidump\040320-18906-01.dmp
Here are the dump files.
https://drive.google.com/open?id=1CX8dR1aB5PYMc38dhooT8yWP8vcH0-hq
https://linustechtips.com/topic/1172883-pc-crashes-randomly-please-help/
