Printer working on Wifi not on network
Solved by Kilrah,
Well there's more setup to do with a router...
It should be put in access point mode if it supports that. If it doesn't then disable the DHCP server on it and plug all your devices (including the modem) to the LAN ports, leave WAN empty.
Featured Topics
Lythyum ·
2
damian61 ·
Posted in Troubleshooting0 -
BrandBoozle ·
Posted in Troubleshooting4 -
1
mecurt78 ·
Posted in Troubleshooting1 -
8
jonrosalia ·
Posted in LTTStore.com Merch1 -
amir2927 ·
Posted in CPUs, Motherboards, and Memory4
