Hey there. Got some questions, got some info:
  • Which RTX 2080 are you planning to get? Graphics cards from different brands/manufacturers may have different lengths/number of fans. (For example, EVGA GeForce RTX 2080 XC2 GAMING (2 fans) is 269.83mm, but MSI RTX 2080 GAMING X TRIO (3 fans) is 327mm.)
  • Will you be using the NZXT H440's HDD cage?
The NZXT H440 has a graphics card clearance of 294mm with the HDD cage, or 428mm without the HDD cage.
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
https://linustechtips.com/topic/1172242-i-need-help/#findComment-13436270
I am planning on getting this one Asus GeForce ROG Strix RTX 2080 OC and i have an hdd, do you think it will fit?
https://linustechtips.com/topic/1172242-i-need-help/#findComment-13436495
The ASUS ROG Strix GeForce RTX 2080 OC is 299.7mm long. Hm...
In theory, if you remove these two drive bays (highlighted in green), you may be able to accommodate the graphics card and still mount your HDD in one of the other drive bays. The only issue is that I don't know whether the space has enough width clearance for the graphics card (width is 130.4mm). If you have the case in your physical possession, you could probably check?
正直に生きる、一度きりの人生だから
https://linustechtips.com/topic/1172242-i-need-help/#findComment-13436538
