I have Coolermaster MasterAir MA410P and when rendering a video in Adobe Premiere,CPU cooler vibrates quite a bit.When gaming it's all fine,but when under max load,it seems like cooler has to work hard to keep the cpu under 70 degrees celsius.Is that normal or i should tweak it somehow?
CPU: Ryzen 5 2600,stock clocks
vibration is most likely some kind of imbalace in the fan. you could try swapping the fan out for a high quality one like a Noctua.
1 minute ago, Cheeky Bugger said:
I will do that,thanks for the help
alternatively you could set the fan curve in your BIOS to a slower one, tough that would likely also yield higher CPU temperatures.
Damm,you were right about the imbalance of the fan,i had look and i noticed i've placed the fan a bit too high on the cooler,now its more centered and it's not making that vibrating noise,also i think the temps are lower since i can hear the fan is not spinning at that kind of high rpm as before,thanks a lot
Just gonna note that it still vibrates, even if it doesn't make any noise. If you touch it, you might feel it. My U14S does that even on lower loads. Doesn't make sound, just vibrates.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Could that hurt the CPU?
If it's tight, no. CPU has the retention arm to keep it in place and cooler would need to be rocking loose to harm it.
