https://linustechtips.com/topic/1171930-first-build/#findComment-13433737
https://linustechtips.com/topic/1171930-first-build/#findComment-13433750
I would go with something like this, spending more on a decent case so you can use it as you upgrade your system. The Ryzen 5 1600 I linked is the 12nm which is basically a 2600 in everything but name. I think for $70 less than the 3600 it’s a pretty good deal, but the 3600 will last you longer.
https://linustechtips.com/topic/1171930-first-build/#findComment-13433781
Tehre are some good buils, so i wont create my own homever i will talk about your choices.
cpu: i5 8400. is 6core 6 thread cpu with under 4ghz turbo. And ryzen 5 3600 has 6cores, 12 threads and over 4ghz turbo. Ryzen 5 3600 is way better than i5 8400.
gpu: 1050 ti sucks. Rtx 2060 KO is much better. Like its unbelievable better.
psu: instead of cxm get cx 550w. Cx has modular cables, cxm is semi modular.
ram: 16gig is enough for every game
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1171930-first-build/#findComment-13433786
