Hello, so I bought my PC a few years ago and the only problem I'm running into is that my GPU is outdated, as it is the Geforce GTX 960. I notice I can not run any more demanding games. So I'd like to upgrade it. However, right now my PC is equipped with a 350W psu, while for the new GPU I will need at least a 450W psu. Since my pc is prebuild, and it is very small I'd like to know if someone knows any 450W+ psu's that have smalled dimensions? Preferably smaller or the same as 19x10x4 (LxBxH).
I really hope I can be helped out.
https://linustechtips.com/topic/1170899-small-psu/
What is the make and model of this PC? Which GPU are you planning to upgrade to?
https://linustechtips.com/topic/1170899-small-psu/#findComment-13424165
For that MSI prebuilt it looks like they are using a flex ATX Psu, I would recommend to look for a unit that is made by a reputable manufacture like FSP such as this:
https://www.amazon.com/FSP-Solution-Platinum-Efficiency-FSP500-50FSPT/dp/B01N4IGM0O/
https://linustechtips.com/topic/1170899-small-psu/#findComment-13424739
Okay, I'll take a look. Thanks for the help :)
https://linustechtips.com/topic/1170899-small-psu/#findComment-13426450
