The peripherals i have picked out are
screen- http://www.newegg.com/Product/Product.aspx?Item=N82E16824236305 would like 23-27" with low MS times
mouse- http://www.newegg.com/Product/Product.aspx?Item=N82E16826153125 For the mouse i would like to know if there is anything better?
keyboard- i will be waiting for corsairs/cherrys new mx RGB keyboard to be released.
The things i have listed, are they good? is there better? I need help and want advice with the stuff i have listed...
please help. Thank you
https://linustechtips.com/topic/117087-need-help/
The mouse is good, my brother has it, solid build quality, looks nice and the mechanical side buttons feel good when you press them.
Those Corsair RGB keyboards will be likely around $125-150, so save up for those.
Also, don't get that monitor :(   It's a TN panel, go for a nice IPS monitor. Latency (ms) GTG is not input lag, it's the time it takes for a pixel to go from gray to a color to gray (hardest task). Something between 5-8 on an IPS monitor will not be noticeable at all.
https://linustechtips.com/topic/117087-need-help/#findComment-1562819
I have the razer deathadder. You can't really go wrong with a razer mouse, I don't need the extra buttons the naga has. That's what my keyboard is for. I just use the two on the deathadder for  melee and grenades with games. So it depends on what games and macros you'll be using. I was going to get the naga originally, but I decided against it since my keyboard has 18 programmable keys with 3 different presets = 48 different macros.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/117087-need-help/#findComment-1562846
What kind of screen do you recommend then???
https://linustechtips.com/topic/117087-need-help/#findComment-1562861
I was originally looking at the deathadder but i did a lot of research and the naga came out on top of the deathadder. So i though to go with the naga. But thanks for the feedback!!
https://linustechtips.com/topic/117087-need-help/#findComment-1562875
