I have a ryzen 5 3600x running with stock coolers on stock settings, but after a few minutes of running at 80-90% it gets temps around 90°-95°. When I had just got the CPU I ran benchmarks to check how much the difference was to the old ones, and the temps went up to 95°+ and the computer shut down. Do i have to buy a new cooler, or is it just enough to reapply the termal paste?
https://linustechtips.com/topic/1170680-high-cpu-temps/
Are you sure that the cooler is tightly secured, enough thermal paste? As the stock ryzen should cool adequately for a non oc stock 3600
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1170680-high-cpu-temps/#findComment-13422609
2 minutes ago, gurannsan said:
Will this lower performance?
no, but gen3 ryzen often has too high voltage. Lower voltage= less heat.
You can also set your cores to 4-4.4ghz. This makes your cpu run at those clocks all the time.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1170680-high-cpu-temps/#findComment-13422662
How good airflow you have (intake fans? outtake fans?) because your gpu is 72c wiht only 4% load?
https://linustechtips.com/topic/1170680-high-cpu-temps/#findComment-13422663
The mode on ryzen master was manual so i thought i light have messed with some settings there so I set it on default settings but then after a restart without doing anything it went to like 80 degrees and powered off. Now I can’t boot at all without a crash. Is there any way to change the voltage in bios?
Edit: I can boot now at 50-60 degrees. Guess it was just overheated to start with. At idle it lies at 50 boost up to 55-60 and slowley goes down to 50 btw. It has done this since i got it, as well as getting the high temps. It is now locked at 1.01 volts too, but it seems like the temps are still the same. I will try to reapply the termal paste, and if that doesnt work I'll just buy a new cooler or something.
https://linustechtips.com/topic/1170680-high-cpu-temps/#findComment-13422722
