All right so basically I have a computer which held
gigabtye h110m-h-Cf rev 1.0
ram 8gb
intel Pentium G4560
gtx 1050
power supply was a casecom technology 550W
so basically I got a new psu and a new graphics card. One be like a Centauro 0600W 80 bronze and i also got  a GTX 1070. So me being me. I just unplugged my computer not doing anything like bios or whatever. And tried to see if my psu worked. So I unplugged the 24 pin or 12 pin I forgot but didn’t unplug anything else. And I plugged in the new psu and turned it on and I thought I got a broken psu because it didn’t turn on but after with some help and fully replacing the psu and putting the new graphics card in. I went to go plug in it. But to my suprise there was no display nor my keyboard or mouse didn’t connect. Later finding out that the 4 pin wasn’t connected then turning it on to find and hear 5 beeps then restarting and turning off restarting the same process
after basically taking the pc apart and learning it is a CPU Error we tried taking out the cpu turning it on no beep. When putting the metal cover on And tightening it the 5 beeps happened. I also believe that my motherboard is fried as I can’t display or anything else.
I’ve tried loads of things like taking out the battery re seating everything and nothing
plz help :(
https://linustechtips.com/topic/1170351-pc-problem/
ram 8gb
intel Pentium G4560
gtx 1050
plz help :(
Try starting it with the original PSU and with the original/or no gpu.
https://linustechtips.com/topic/1170351-pc-problem/#findComment-13419585
ram 8gb
intel Pentium G4560
gtx 1050
plz help :(
and you definetely didn't need a 600W PSU for this. Also the GTX 1070 with Intel Pentium? That's not going to get you any far.
https://linustechtips.com/topic/1170351-pc-problem/#findComment-13419587
ram 8gb
intel Pentium G4560
gtx 1050
plz help :(
at this point I think it's time for a FULL upgrade. CPU, Mobo, Ram and you can keep the 1070 as that's a good gpu. If you do decide to go this route people can help you in the New Builds and Planning section of the forum.
https://linustechtips.com/topic/1170351-pc-problem/#findComment-13419589
