SX-636, 70's retro case
saarwii
So this my first build for since forever and my first custom case ever! I've been planing and planing for months now and this morning i put in my first order for the parts that is going in to this case.
I've been looking for a case that would fit in to my living room but didnt find anything that really grabbed my attention. But about 2 months ago i walked in to a thrift shop and saw an old 70's stereo sitting on the shelf. no power or sound in it but hey! this could work as a computer case. So i payed the man his 30 bucks and i was of to the land of custom case bulding!
So this is the case, it's an pioneer SX-636.
this is how it look in my living room
So....it's small... only 16 cm heigh and 12 cm inside the case about 45 width and 33 depth.
i will fill this case with the following components
UPDATE ON COMPONENTS!
Motherboard: ASRock Z87E-ITX
CPU: i5 4670k
GPU: EVGA GeForce GTX 770 SC ACX HDMI DisplayPort Dual-DVI 2GB
Riser card: Deltaco Raiser-54
RAM: 2x4 Corsair vengeance LP
SSD: Samsung EVO 840 240GB
HDD: Seagate SSHD ST1000LM014 64MB 1TB 2'5
PSU: Be quiet! 530w cm
Cooling:
1x Corsair h75
2x Aerocool DS 120mm.
1x Noctua NF-B9 PWM 92mm
2x Fractal Design Silent Series R2 50mm
MODS!
Volt mod 50mm fans to run slower and quieter
Connect case indicators to show readings from components.
LEDs to back light the frontpanel
New case backplate.
So i've scraped the Kraken g10 mod for now! to much work at the moment with everything else that have to been done! in short i have to do mods on the GPU to fit the g10. I have to install a fan controller and thermal sensors to be able to auto control the fans or install a manual fan controller on one of the front ones!
So now i have two 50mm fans + a better psu to get rid of the hot air. and one 120mm aerocool ds and a noctura 92mm to get fresh air in. Also a H75 with an aerocool fan for better cooling and lower noice on the CPU.
But as you can see on the layout i will be able to put in like a h55 or someting in the case i i would want to go with the kraken in the future!
So new layout!
NEW LAYOUT!
Seen form above
In the future if steam os takes off i will have one ssd with windows and one with steam and i will convert two of the buttons on the front panel to chose which hard drive to boot from on start up
So while im waiting for parts! here is my badly photographed case tear down
so much dust
Mobo plate
The reassemble to se how mush room i had to work with
Edited by saarwii
oh my gud
Specs
I'm interested...
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
Very intrigued.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
I know they dont do it anymore but they should start back Build Logs of The Week just for this. +659234574653804703284982764583450817364108745603465108946508347650234865293847650384765023847650283406523. Epic.
So i changed the order for to:
2x Antec H2O 620 V4 (Since i would have to change out the stock fan regardles if i got the antec or the Corsair h55, i went for the cheaper 620 and two great fans).
​the motherboard should arrive tomorrow
The rest of the stuff friday or monday. So it's probably going to be on the down low on updates over the week end
So new layout!
NEW LAYOUT!
got the first parts jester day! still waiting for the cooling, psu and mobo but i've started to do some planing on the GPU
sweet smell of GPU
time to try and take it apart
It came of easy, one screw under the card and the DVI port scews and it was off
The plan was to mount the card directly to the case backplate! but it seems like it's alittle bit over my head so im going for a custom plate insted
More on tuesday when the building will start!
Sweet, I love the look of old sound systems, rocking a few in my room currently.
Maybe you could try to make the switch on the unit turn on the PC.
Stock coolers - The sound of bare minimum
If it were me I would black out the GTX 770 like how EVGA did their new GTX 750ti. That card is absolutely sexy.
rawr!! I'm a ferret!
So Everything is here (almost, i might need 2 more fans). Tomorrow or the day after i will start the building process
Everything (sorry about the focus)
-First up is creating a new backplate, with cut out for mobo, gpu and psu and the 50mm fans I will also need to paint the I/O shield (i have read som horror storys of people trying to create their own shields so i wont go in to that this build)
-Second is to create a new mounting plate for the GPU and paint it
-Third it's is on to mount the components to the botomplate and cut out air intakes on the bottom.
-Then i will have to create 2 fan controls, one for the intakes in the front and one for the H75 fans.
- alter the current power button to a momentary button.
- attach LED for the back lighting of the front panel
- Add two temperature meters, one for the GPU and one for the CPU that you can read from the analog indicators on the front!
OLD LAYOUT
Original Layout of the case.....minus the mobo(i fits i just didnt wanna mess with at this point) The GPU( going to be horizontal in the middle with a riser card) and the SSD/HDD, (They are going under the GPU)
NEW LAYOUT
I think im going to go with this one! going to look better, and be a more quiet set up.
Holy sh*t mate, awesome, can't wait for an update.
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
Looks fantastic so far! Can't wait to see it done.  :)
you and me both! im writing my bachlor thesis parallel to this build so i have lot to do.  I hope il get it up and running before this weekend, and fully modded and done with all the knobs and switches next or next one again.
The plan is to have it up and running before thief is released.... So friday...:P
