-Moved to Troubleshooting-
Please post your image here, without the outside link.
https://linustechtips.com/topic/1169995-i-need-help/#findComment-13416537
I'd say most likely Opacity and Contrast.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1169995-i-need-help/#findComment-13416547
5 minutes ago, drmegamer said:
my friend wants the exact same thing... Could you help?
Well I've never done it I only did something similar to my animated text on my start screen using just those two options. Sorry, if I knew exactly how I would.
You'll have to play around with it but if you have done it just have him copy your color correction settings. I do like it, unique design, better than having a actual face cam IMO. :)
https://linustechtips.com/topic/1169995-i-need-help/#findComment-13416570
Thing is he wants the exact same thing
https://linustechtips.com/topic/1169995-i-need-help/#findComment-13416603
Are you using it or is this from a random on youtube?
I can't do it I don't have face cam to try it with.
https://linustechtips.com/topic/1169995-i-need-help/#findComment-13416611
12 minutes ago, drmegamer said:
Its from a streamer on twitch called pixelpeet
Never heard of him. I would say do something someone else isn't doing but just have your friend play with those settings or better yet google it how he does it.
https://linustechtips.com/topic/1169995-i-need-help/#findComment-13416675
