I just bought an asus tuf b450 plus gamer ATX mobo. But it did not have any standoffs or m.2 screws. Wheres the quickest place yo buy them and what size fo i need. Any links to sellers would be apreciated. Are the mobo and m.2 standoffs a different size. Cheers for all your help.
https://linustechtips.com/topic/1169881-please-help-standoffs-misding/
Standoffs come with the case.
M.2 screws might be in the M.2 slot already
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
This got me on my first PC build too. I knew the standoffs came preinstalled in the case, but I thought that the screws were supposed to come with the motherboard, which they didn't. I actually purchased an extra thing of screws from amazon, only to find out that the screws came in a box that was hiding back in the hard drive slot of my case. Check your case and make sure there aren't any screws hiding in there somewhere.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
