GTX 970 running hot
Solved by lexidobe,
I have an update. I decided to screw one screw in at a time and test temps after installing every screw to try to determine exactly which screw(s) is causing the problem. What I found is that the problem actually seems to have gone away after I spent an hour screwing a screw in, testing, shutting down, screwing another screw in, and repeating. I don't understand this at all, but I'm glad it's fixed. Temps now stay at around 50 degrees under load with the fan at 100%, much better. Thank you to everyone who replied, I really appreciate your input!
