I think you'd only be able to do this if you case has water cooling grommets.
You could drill a hole in the back for the wires to pass through, cut the ends of the wires (or undo them if its a 3 pin connector) so the hole doesn't have to be too big. Then redo the ends of the wires. I wouldn't worry about the wires being cut from the hole because it doesn't move a lot, but if you would be wrap some electrical tape around the all the wires together to make one big bunch. Would prevent it from cutting through.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
I recommend something like the Antec Accent Lighting if your planning to do something outside the case and don't want to drill extra holes or run wires since it runs off a USB port.
Skip to around 3:10 you may be interested in doing that.
