CPU not being utilized
Solved by Guest,
It might just be Interweb lag causing the Frame drops. My left leg can run 50 fps on fortnite.
Need more information.
Are you watching the HD/SSD usage? any spikes on read writes?
What about the GPU? Are the clocks staying constant?
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
