So I'm currently helping my parents put internet in the opposite side of the house.
The east side currently has the router and the wifi isn't strong enough to reach the west side...so the plan was to run a 100ft (30meter) ethernet chord to the west side and then setup another hub.
I'm not really sure what would I need to setup this new hub... Also could I run another short 10ft (3meter) ethernet chord from that hub to a desktop without any worries of latency?
If running that short chord from the 2nd hub would have a large impact...I can get 2x100ft(30meter) lengths.
I've never dealt with these kinds of questions/problems... much better at computers lol... thanks in advance
https://linustechtips.com/topic/1168564-internet-help-extension/
Take the 30m cord plug it into a switch at the destination and then plug as many cables to as many devices as you want from that switch.
If you just want to extend the range then get a WiFi range extender and place it somewhere in the middle of the house. It will connect to your existing WiFi, boost it back to full signal then create a second SSID for the users on the other side to connect to.
They're really simple to set up (even easier if your router supports WPS) and much cheaper than running cables & buying hubs/switches/routers etc.
Main Rig:-
Server:-
This is probably what I'm going to do since I can't use a wifi extender due to a really thick wall in the middle of the house that blocks signal
As per others just run that uplink to a switch.  There shouldn't be any increase in latency, the forwarding on the switch is done in hardware at sub ms levels.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
there may not be a need for a switch if his 2nd wifi unit is a router/wifi combo unit. those often have 4 ports which would give him a run to his desktop.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
In comparison, however, they will perform like garbage :(
I've got a Netgear one and its solid as a rock and runs at full speed for all my stuff downstairs that otherwise gets a weak signal. In fact in 12 months I've literally never had to touch it.
Main Rig:-
Server:-
