5 minutes ago, AustinForce said:
how much loss of performance do i loose i get if if i go intel instead of amd also what is the best 1 thousand intel build i got a rx 570 already
What do you mean with performance loss?
What kind of system do you want to make?
What do you want to do with this computer?
https://linustechtips.com/topic/1168562-help/#findComment-13403861
well what i mean is intel is alot more expensive then amd for their cpus and i hear from a friend that if i go amd ryzen ill loose 10 fps or more and i wanna build a intel system and i wanna game and stream a i7 would be ok i just wana know if its the right choice or if i should go cheaper
https://linustechtips.com/topic/1168562-help/#findComment-13403871
Well this is a very open ended question.
It depends on a lot of variables, What do you intend to be doing with your machine?
47 minutes ago, Harry777 said:
a lot
not contributing, lets put more thought into that answer.
Apparently your friend needs to be a bit more explicit with is explanations and a bit more informed.
Loss of FPS is not a gauge to by unless that is all you are focused on. Performance is based on other things like for instance, some games perform better on single core, some games perform better on multi-core. Other times it is not the CPU performance that is the issue, it may be the GPU and it drivers that could the be the issue. Background applications, internet latency (if your playing online), power draw from the PSU ... etcetera.
Like I said there are many variables involved.
List what you are expecting, the loads you plan to place on the build. What is your goal with the build?
Also
-= Topic Moved to New Builds and Planning =-
Edited by SansVarnic
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1168562-help/#findComment-13403936
