I have been trying to find a nice mechanical keyboard for a long time. I found a Logitech g610 Orion brown. I like it because the lighting is perfect for me, and also the media keys are gorgeous. In my opinion. But I couldn't get it shipped to me or it was like double the price it should be. I also tried to find the red edition but with the had the same result. Can anybody help me find an as a similar keyboard as possible?
Thanks
https://linustechtips.com/topic/1168239-my-keyboard-problem/
Thanks
Keyboards are quite personal.  Your talk about aesthetics and “just the right light” make it nearly impossible to even suggest things because the criteria aren’t defined.  I can tell you that the cherry switch went out of patent and there are a vast number of clones out there.  The problem you may be having is you want a cherry switch keyboard for a clone price which I suspect is unfindable.  The best thing I can suggest is looking at the LTT keyboard reviews.  There are several.
https://linustechtips.com/topic/1168239-my-keyboard-problem/#findComment-13401145
