Hello everybody I just want to get you opinions and suggestions on this build. I'm trying to get into PC gaming as cheap as possible while having a clear upgrade path. Here is the build
CPU: AMD Athlon 3000G ($46)
Mobo: Asrock B450M Steel Legend ($78)
RAM: Team Group Dark za 3600mhz ($90)
Storage: 240GB Western Digital Green M.2 SATA ssd ($32)
PSU: Cooler Master MWE 450W 80+ White ($33)
Case: Cooler Master TD500 ($38)
Cost: $322 USD (including shipping)
Now to make a few things clear
1. The ram is 3600mhz because even 2666mhz is expensive and when I upgrade to Ryzen I won't have to upgrade the ram.
2. My choice of parts is such because I want to keep the cost of upgrades as low as possible. Now this does result in some short comings such as the power supply however 80+ PSUs are cheap in Malaysia, so PSU upgrades won't be too costly.
3. I live in Malaysia so there is a price gap between components here and say for example in America. Some products are not available here as well for that matter.
If you do have any suggestions please do tell me. My budget is about $300-$350 USD. You can use Lazada or shopee
PC: Ryzen 5 2600, 16GB 3200mhz RAM (8GBx2), Gigabyte B550M DS3H, GTX 1050 2GB, 650W Semi-Modular PSU80+ Gold
Phone: Poco F3 8GB + 256GB
Audio: Samson SR850s
Sound Card: SoundBlaster Play 4 USB sound card
IEM: planning to get the KBEAR KS2s
Please be patient with me, I'm fatally dumb and its honestly a miracle I've made it this far
https://linustechtips.com/topic/1168063-first-build-advice/
There are a few models that you might find affordable, see if you can fit one into your budget
Cooler master masterwatt V2 (bronze or white)
Be quiet system power 9 (400w or up)
Corsair CV650, CX450, CX450M
You can check out our PSU tier list to see more units to compare
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13399505
Very well I'll see if I can fit an 80+ bronze and higher wattage if I I can
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13399968
there are 80+ bronze power supplies that are just as bad, aim for a quality PSU
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13399976
Any recommendations? Around $40-50 USD?
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400081
I found this one for $50 USD.
Then theres the Corsair for $60 USD
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400086
USD doesn't make any sense, you're buying from Malaysia.
The MWE Bronze 600W is tier B, so it's good.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400090
I'm converting the price for your convenience
But ok then I'll go for the Cooler master then
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400092
Yeah but I don't know any of the prices in Malaysian markets so if I recommend a $50 PSU it could be super expensive for you. Products are almost always a different price in other countries.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400094
True but no worries the cooler master PSU is exactly $50 USD and is within my budget
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400101
That's pretty good. In USD it's actually a lot more expensive, I wish the better MWE models were available at good prices.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400107
I'll probably be wishing for the same as I upgrade the components.
BTW what do you think of the other components in the build list?
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400146
It's basic, but you picked a solid motherboard and good memory. If you wanted a guaranteed motherboard supporting 3rd gen ryzen, look for the Asrock B450M/AC or the MSI B450A-Pro MAX.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400149
The Asrock is not available here and is the msi one supposed to be 2-DIMM slot cuz that's the only one I can find.
Not to mention I won't be going to 3rd gen ryzen immediately, I'll upgrade from the Athlon 3000G to the Ryzen 5 1600 AF and then I might upgrade the the mobo for 3rd gen Ryzen
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400158
Athlon 3000G is third gen
Any of the MSI MAX motherboards are ready for third gen out of the box, but if you can only find one with 2 slots it's no good.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400160
Oh well seeing as it's an Athlon I'm assuming most motherboards will support it
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400295
only motherboards that are compatible with 3rd gen Ryzen are compatible. It's not that the CPU is too hard to handle, just that it's new.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13400319
I see
https://linustechtips.com/topic/1168063-first-build-advice/#findComment-13407592
