Hey Guys,
I once again had a question. First, let me lay out my custom waterloop configuration:
1. Massive reservoir consisting of two large +/- 2 liter bricks, connected by a 45 mm wide pipe, holding 4+ liters, because it looks gorgeous, it doesn't hurt in any way, my case has the space, pump won't run out of water any time soon and why the hell not?
2. Dual EK Revo D5 pump apparently in serial mode;
3. A combined length of the waterloop (front and back) of about 5 meters;
4. 2 360 radiators + 1 120 radiator.
5. Order: Res - pump - rad - cpu - rad - GPU - rad - exit.
Given that everything is rather large, I reckoned one single pump would not pull the stunt, although I previously had a single EK Revo D5, which performed, but the outlet was kinda measly, indicating that it had a lot of trouble pushing the water around. So I decided to get a dual pump, because hey, double the pump means double the power, right?
Now, it started out enthusiastically with a good solid outlet that somehow impressed me. But now, after a week, ten days or so, the outlet stream has been reduced to a teenie weenie stream, not as measly as previously, but not much butter. The system is all bled out and as far as I can see, there are nowhere any bubbles in the loop that should concern me - a few tiny ones here and there.
Anybody has any idea how the reduction in performance came to be? I have the pump only on molex as I learned that this way it performs at 100%.
Do EK Revo D5 pumps gradually slow down over time? Or is this normal behaviour? It looks like it as it worked very well at first, ergo the size of the loop might not be the problem. Hope anybody can help me on this one. Thanks!
Gr,
J.
My new current system:
MoBo: Gigabyte Aorus x570 Master | CPU: AMD Ryzen 9 5950x | RAM: G-Skill Trident Royal 32gHz @ 3600 mHz | GPU: Zotac RTX 3070 Twin Edge OC | SoundCard: SoundblasterX AE5 white pure| Storage: Toshiba 3TB; Seagate 2TB; WD Blue 4TB; Seagate 8TB Samsung EVO 980 500 GB PCIe 4 NVME; Sabrent 500GB PCIe 4 NVME x 2 | Case: Thermaltake the Tower 900 | Monitor: Toshiba HD 32"; Dell 24"; 7" hardware monitor LCD | PSU: Corsair RM850i | Propellors: Thermaltake Riing plus 12 x 8; Thermaltake Riing plus 14 x 3; Thermaltake Riing sync 12 x 2 and 5 other propellors for a push-pull config on a 360 and 480 rad | Cooling and remaining stuff: dual custom loop with a) one EK D5 Revo pump and b) one EK D5 Quantum Inertia pump.
https://linustechtips.com/topic/1167835-pump-question/
27 minutes ago, Jojobaplant said:
Coolant used, waterblocks in the system, and photos of the system would be helpful.
https://linustechtips.com/topic/1167835-pump-question/#findComment-13397795
Ah yeah, forgot: coolant now used is EK Cryofuel solid; Waterblock CPU: Alphacool's Eisblock and GPU is a MSI Geforce 1070 Seahawk. I will post pics later on when I get the chance.
As for the coolant - I used Mayhem's Nuke previously, which is non-opaque and the issue was the same.
Also, I used to use EK's monoblock for my mobo, but I learned that this provided too much resistance, so I changed it for the smaller Eisblock.
https://linustechtips.com/topic/1167835-pump-question/#findComment-13397804
Guaranteed one of your blocks is clogged.  A single D5 pump should be able to push TONS of water through any desktop loop that isn't 5+ blocks.  I can set my pump to 2 / 5 and it'll be sufficient for a cpu + gpu loop with close to 10 feet of 3/8" tubing.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/1167835-pump-question/#findComment-13398555
