I'm having issues with some games being choppy, and framey while streaming games like Fortnite. I use Streamlabs OBS. I know my hardware is good enough to handle it, I've streamed it before with no issues but this time around I can't figure out the fix, I have friends with lesser PCs that don't have this problem. Ive read every forum and watched every video.
I have i7 8700k OCd to 4.5, 1080ti and 32GB of Gskill tridentz DDR4. My last speed test I had 11 ping, 432 download and 982 Upload so I know my internet is not the problem. Hardwired of course.
I'm streaming at 144fps, both my main monitor and monitor with streamlabs are 144fps. I know that was some weird bug they had.
Base canvas: 1920x1080
Output scale: 1280x720
Downscale filter: Lanczos
Common FPS value : 30 or 60
Enforce streaming service encoder is checked.
Rate Control: CBR
Bitrate: 5 or 6000
Profile: Max quality
Profile: high
Psycho Visual tuning checked.
OBS doesn't tell me my frames are dropping and my fps always sit at 144 but you can easily visually see the game is choppy like its under 60fps. Regardless of my in game settings this happens. I hide the preview, go into performance mode but it doesn't change anything. Any help?
https://linustechtips.com/topic/1167505-streaming-issue/
My issue went away after i used the capture software in the background on my main monitor.
Never used to be an issue but after 3 different softwares i've came to the conclusion it must be a Windows thing, possibly after an update.
Hope you get it sorted fella!
https://linustechtips.com/topic/1167505-streaming-issue/#findComment-13406139
