Asus M32CD - AS51 motherboard to front usb hub SATA wiring. USBs don’t work
31 minutes ago, cobalt77 said:the left USB may actually to actually go to the black (FIO_CON1) not the white (CR_CON3) connector.
Yup indeed, my bad, even noticed it with the names but promptly forgot about it by the time I wrote the post. CR_CON likely stands for "Card Reader" and thus would be one of the USB2s.
I have no idea what the 4th is for, there are 2 for the USB3s and one for the card reader, but why a 4th? Unless they are splitting things as much as to have the USB3's high speed lines on one SATA each, and the USB2 lines for both ports in the 4th connector... in which case the order of the 2 USB2s might matter. It's a pile of mess.
This front panel might have been designed looong ago before the 20-pin USB3 header was introduced, at least I hope so...
