Hello everyone
I'm planning to upgrade my current GTX 970 to 2080 sometime in the summer. The only problem is, I'm not sure my motherboard and the rest of the system can handle it. Any advice?
My current system specs:
Intel i7-6700k 3.40Ghz
z170 pro gaming
16 Gb RAM
Asus GeForce GTX 970 Strix-4gb
evga 750w power supply
https://linustechtips.com/topic/1167083-i-need-help-with-pc-upgrade/
looks good to me.
PSU has enough wattage and your CPU is no bottleneck with a RTX2080.
  • CPU
    Intel i7-8700k
  • Motherboard
    ASUS ROG Maximus X Code
  • RAM
    32GB Corsair Vengeance LPX DDR4 3000MHz
  • GPU
    2x ASUS Strix 1080Ti OC
  • Case
    Fractal Design Define R6 Gunmetal TG
  • Storage
    250GB Samsung 960 EVO
    2x 500GB Samsung 850 EVO
    1TB Samsung 860 EVO
    2x 256 GB Samsung NVME SSD
  • PSU
    Corsair HX1000i
  • Display(s)
    Alienware AW3418DW 34" 21:9 1440p
  • Cooling
    Custom watercooling loop with 2x 360 Rad + 1x 560 Rad
20 minutes ago, busyelton said:
Hello everyone
Make sure your case can accommodate the length and height of the graphics card. The included coolers on many of today's graphics card can be huge depending on which manufacturer you get it from. Look at the card length and use a ruler to see if it will fit in your case and be able to clear other cables or components that you already have.
Also, check to see if your PSU has the relevant number of plugs to support the GPU.
