hey, im having difficultys with my pc. im having problem with every task im doing, even playing a yt video. so the problem is im having random freezes and audio freezes/lags every 10-40 mins. i dont exactly know whats causing it but im pretty sure its not the windows/ram. ive ran a test on a program called latencymon and thats all ive got. let me know what tests i should do to help give more information about the problem and i will. ive been having the problem for like 4 months now and its pissing me off.heres some pictures that might help : (bios is last version btw)
PARTS:
amd ryzen 7 3700x
rx 5700xt nitro +
2x 1tb samsung qvo
asus prime pro x470 motherboard
2x8 3600mhz gskill ram
 latency.thumb.png.904c9b28821299ef59342a03c4bdc88f.png2.thumb.png.97b3a4f288a8f7f7f50cb59602c138d1.png1.thumb.png.609c34ed765e9b832e89092967c447ca.png
https://linustechtips.com/topic/1166953-random-freezes-need-help/
@Mythical2 Could this be a heat issue?
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
@Mythical2 Also try updating Video Card drivers and any Codecs that are used for Video and Sound.
I use the K-Lite Codec Pack and have done for years with no problems, u can get it from here..........
U can download the pack from here......  https://codecguide.com/download_k-lite_codec_pack_mega.htm
Once downloaded and installing choose to install Lots of stuff.
Internet Speed.....
cpu on idle is around 40s-50s and gaming is 40-65c
gpu is maximum 74c
mobo is like 45c
and my 2 ssds are like 40c
dont think any of it should be an issue (also ill type my parts up so it might help
@Mythical2GPU is a little on the high side but i dont think is the cause.
Try what ive suggested in the matter of upgrading drivers and codecs to see if this makes any difference.
Internet Speed.....
grapics drivers are latest and i reinstalled them multilple times.. just a question, what does this program do?
@Mythical2It just installs every driver\Codec u will ever need to play any type of video which includes video and sound.
Internet Speed.....
also im having the lag in games and such and an audio lag during the lag.. happens in everygame, do you think it might solve it since its not a video?
@Mythical2It might do, if not what i would then suggest is disabling the onboard sound and using a 3rd party sound card.
Internet Speed.....
@Mythical2 Setup looks correct but if the sound card is faulty whatever way u set it up its not gonna work,  As i said u could try disabling the sound card in the bios and using a 3rd party card instead.
Internet Speed.....
does it have anything to do with the lag?
@Mythical2Ive seen faulty hardware causing lag so yes it can be.
Internet Speed.....
