Hello,
Here are my PC specs:
Ryzen 3800x
MSI B450 Tomahawk Max
Gigabyte Rx5700XT
16 GB G-Skill 3800 (8x2) Ram
TP Link PCIe 1x WiFi card
Antec Ne650 PSU 650 Watt
Well everything turned out fine with the build and everything ran smoothly until I tried to play a game (Bus simulator 18 lol)
I experienced a lot of black screens every few seconds and a quick Google search showed that I needed to enable legacy mode?
After enabling legacy mode I started the game again, but the black screen issue was not fixed,then I restarted my PC.
Now after restarted , the same black screen issue "spread" to my OS (Windows 10) as well and I am unable to do anything cause of the black screens.
Monitor says no input during the black screen and then it suddenly shows my desktop again and the when I try to do anything it again goes blank.
I tried going to the BIOS and everything worked fine in bios without the blackouts
Any fix ?
https://linustechtips.com/topic/1166881-black-screen-issue-please-help/
Is this legacy mode in the game or somewhere else?  If it’s in the game perhaps it resets low level stuff but doesn’t reset it correctly again.  Maybe open the game, turn off the legacy mode, close the game, and see if win10 is still doing it?
Idk if this was the problem, I just enabled legacy mode in Windows, I somehow disabled that legacy mode having these constant blackouts .. but it still didn't get fixed
“ somehow”.  Sounds like maybe something tripped something else.  Perhaps enable and disable it in windows?
I basically did this:
https://teckangaroo.com/enable-direct-play-legacy-component-windows-10/
Just now, wilsonyolo said:
I think this is unrelated to that,and it's some sort of graphics drivers issue?
But the problem is , everything worked fine until I played that game .
