I have a budget of $1500. I need a gaming rig and am thinking about using AMD Ryzen5 3600. I need help with choosing the following:
- X570 Motherboard
- Nvidia GPU (Possibly RTX)
- PSU (Gold)
- 16GB RAM
- Monitor
- Mouse
- Keyboard
Also windows 10 Home is included in the budget
https://linustechtips.com/topic/1166671-new-first-time-build-need-help/
- X570 Motherboard
- PSU (Gold)
- 16GB RAM
- Monitor
- Mouse
- Keyboard
If you are not planning on upgrading your CPU,you should go with a b450 motherboard
https://pcpartpicker.com/list/PkNf27
You do not need a x570 board for r5 3600. And that msi board will support future ryzen processors good enough
16gig 3600 mhz memory with 16 cas latency. Sweet spot for ryzen.
That adata m.2ssd is very fast and cheap for its performance. 2 tb hdd for large files.
One of the cheapest rtx 2060 super (not bad rtz 2060 super though). I would suggest you to get rx 5700 since its a  better than rtx 2060 super and you can  bios flash it to 5700 xt (for extra performance) and its a little cheaper.
Phanteks p300 is a good and cheap"ish" case.
Very good psu.
Now i do not know much about peripherals or monitors.  But 1440p 144hz ips panel will do good.
You coul get cheaper keyboard (mayby corsair k68 or k70) but my friend has that keyboard and i love it!
The mouse is really good for the price.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
