When I try to boot my pc I get a red light for cpu and I have occasionally seen one for vga (video).
I suspect it's because of using a 4+4 power cable instead of a 8pin.
My config is:
CPU: Amd ryzen 7 3700x
Motherboard: Msi mpg x570 gaming plus
GPU: Gigabyte rtx 2060 super gaming oc 3x white 8g
RAM: Corsair vengeance lpx ddr4 2x8gb 3200mhz
PSU: sharkoon silent storm cool zero 650w 80plus gold
SSD: samsung 970 evo M2 and a USB with windows 10
Does anyone see a problem in this config. Sorry for the terrible pic.
Edit: I am now also getting a vga error and the monitor only shows one underscore somewhere in the middle left of the screen.
https://linustechtips.com/topic/1166513-need-help-system-gives-cpu-error/
@piratemonkey How do I know if the cooler is mounted correctly? In my aspect it's fine. I have de handle to pressure it down on the top side (if it would be in a case)
I didn't saw any bend pins on de cpu and did fit it in correctly.
@jeroendn as long as pressure is even, it shouldnt be an issue. i would try with one stick ram, all slots. the monitor showing only the underscore i think is a bios problem. this was happening with someone i was helping yesterday i think. ill look into that
Either @piratemonkey or quote me when responding to me
@piratemonkey One RAM stick doesn't make any difference. The cooler should be even, but will double check. (I'm questioning why a slight pressure difference could be a issue though.)
I'm now gonna get some night rest myself. Thx in advance for helping.
a slight change in pressure doesnt make a difference, except on threadripper. if one side was barely attached and the other was, that may pose a bit of a problem. the cooler should be fine. again ill figure out what is happening with the weird post. dm or tag or qoute me when youre up and ready :)
Ok, I got my pc to boot today and successfully install windows 10. But everytime I boot my pc the red light for CPU turns on for about 2 sec and then the same for VGA. Then a underscore appears on my screen, before showing me a MSI logo. Is this light thing normal, cause it makes booting take longer? I don't want to have anything in my config wrong and break a component, because of this.
Is there anyone who can tell me more about this?
that's exactly how my pc boots as well. not sure if normal or not
