So recently, I realised I tried to install a game on my SSD (C:). It said there was a disk write error. So when I went to search c: nothing appeared, only NVIDIA Control Panel etc. I tried it with my hard drive and I searched d: and it showed my hard drive. Can I make it so that when I search c: my SSD will pop up?
Thanks.
https://linustechtips.com/topic/1166280-help-ssd-issue/
did you format the SSD.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1166280-help-ssd-issue/#findComment-13385122
did you assign a drive letter to it?
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1166280-help-ssd-issue/#findComment-13385129
2 minutes ago, olleiei said:
Yes
as far as I can tell this just looks to be windows usually messed up search. just use file explorer and go to this PC
https://linustechtips.com/topic/1166280-help-ssd-issue/#findComment-13385132
1 minute ago, olleiei said:
I can't save any steam games to the SSD though.
where is your steam downloaded?
https://linustechtips.com/topic/1166280-help-ssd-issue/#findComment-13385142
https://steamcommunity.com/discussions/forum/1/540742667496603022/
this guy might have the same problem?
if it's similar check out the responses on that thread since he seemed to have resolved his issue
https://linustechtips.com/topic/1166280-help-ssd-issue/#findComment-13385159
