Should I keep my R9 290?
Vhyco_
Hello!
Reciently I had a problem with my GPU and PSU. Basically my R9 290 fried the hell out of my Thermaltake TR2 600W (I know, I've learnt my lesson. In my defense I first bought it with a GTX 750ti.). Now i bought a new, more powerful, certified Corsair 650W PSU and started to wonder if I should change my GPU for something equally powerful but more modern and efficient.
I looked it up and seems that where I live (Argentina) I can buy a brand new RX 570 for just a little bit more of what I can get for selling my R9 290. So that is the question... Should I do it?
For some of you the answer may be pretty obvious. But I can't make my mind up on this.
Thanks a lot!
yes. maybe consider a used rx580 or used gtx 1060 6GB, former should be similarly priced. latter should be a little more expensive.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
I was thinking about that too and I may do it. But in the worst case scenario, a RX 570 should be OK, right?
yes
It's unlikely the card had anything to do with that, 600W is plenty for a single R9 290. If that's your only reason for changing it just don't bother.
I wouldn't, it's barely any faster and only in some games. Definitely shoot for something like a used rx 580 instead, though even then you shouldn't expect a massive boost in performance.
sudo chmod -R 000 /*
I not pretty sure... The PSU I had wasn´t even certified. Since I changed it I noticed much better performance specially in games like F1 2019 where my PC used to strugge with the TR2 600W. I don't know.
Anyway, I was thinking about changing the GPU mostly because of power efficiency/noise issues rather than just performance. That is where I don't know if it is worth the change.
Impossible, if there was a difference in that sense it had nothing to do with the power supply. Insufficient power doesn't cause lower performance, it just causes a shutoff or erratic behavior.
If you have a reference R9 290 then noise will most likely be lower. Power efficiency doesn't really matter, it's a $ or two at most per year.
I don't know... Since i changed my PSU and nothing more than that the loading times in F1 2019 were way better. I'm talking things that took literally 5 minutes suddenly were loaded in 10 seconds. Maybe it is not exactly the PSU but something related with it at least. Also I was playing this game when my other PSU died and happened during one of this loading times...
The GPU is a Sapphire R9 290 Tri X... It is pretty loud with demanding games. It is not worth even for the sake of having a new one with warranty and that stuff?
That's up to you, it's not very likely to spontaneously die.
Okay, thanks a lot!
Sorry to hear that but just wanted to point that out to some people who think that stressing a PSU is not going to harm it... :)
@wkdpaul
As for your question the RX 570 is definitely the way to go (although I would search a bit more usually you can find 580 at the same price point more or less)
I you are going to spend hard earned money I would go for a real upgrade and not a sidegrade.
Power efficiency should not really be taken into account for money sake unless your electricity cost an awful lot, it should be taken into account when you don't want/can't change your psu and need a new gpu that will be able to run with the one you have.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
But OP didnt say he wants to spent more, he said that he can swap it for about the same money indicating that he wont spent more
