So I recently bought a new DELL gaming monitor that's 120Hz, on like my 3 year old gaming setup, and playing games I noticed I really cant reach 120Hz on most of them. Im gonna use GTA 5 as an example, on which I barely reach `70ish FPS, on ultra settings at 1080p, I have a GTX 960 4GB GDDR5 GPU and GTA5 is one game among a couple of other on which I cant reach taht 120FPS, so I'm browsing between choices for a new GPU because It was finally time for an upgrade. Which one would be better between an RTX 2060 Super 8GB, and an RTX 2070 8GB, from what I've checked they are pretty similar, but in a game like GTA 5 which I used as an example, which one of those GPU's would give me the crisp 120FPS im searching for, rest of my computer specs below.
CPU: Intel i5 6500 Quad-Core 3.2GHz
RAM: 12GB DDR4 2133MHz
GPU: Gigabyte GTX 960 4GB GDDR5
SSD: 120GB Gigabyte SATA3
HDD: 1TB TOSHIBA SATA3
PSU: I'm not sure about the PSU but I think it was around 600W or 500W
Monitor: DELL S2419HGF 120Hz 1080p (using Displayport)
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/
2 minutes ago, homeap5 said:
Look at YouTube. If you expect that on ultra settings you can get 120FPS on modern games, then it may be impossible (except very expensive configurations). Lowering settings may help (with new card). And probably you'll see no difference.
GTA5 is one of the games I mentioned, because its the one I am currently playing a lot, and since im already hitting 70~ish FPS on ultra settings and 1080p, I think that a better GPU, would be just enough to hit 120, I dont play extremely high end games like shadow of the tomb raider for example, I guess you could say Im asking specifically for GTA, but other games I play like are The Forest for example, which are not that high end.
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/#findComment-13381183
Your CPU bottlenecks your max/fps and/or refresh rate, probably want to replace that for for 120fps gaming, as you could always drop your graphics down to like 720p low and that 960 can get 120fps at those settings.
Also I think the Navi Cards are cheaper than their 2060 super/2070 counterparts, so probably go for those.
What's your total budget though?
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/#findComment-13381219
1 minute ago, Streetguru said:
Your CPU is a bottlenecks your max/fps and/or refresh rate, probably want to replace that for for 120fps gaming, as you could always drop your graphics down to like 720p low and that 960 can get 120fps at those settings.
budget is around 500$ max i could squeeze out is 600$, since im playing GTA5 rn as i said i want to potentially hit 120FPS in that game on ultra settings in 1080p
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/#findComment-13381221
Looks like you can just barely get a CPU/GPU upgrade
What i would suggest doing is buy the R5 3600 + AM4 Board + RX 5700 if it's that cheap
reuse your current DDR4 RAM
Sell the old stuff
Buy 3600mhz CL16 RAM
Assuming your PSU isn't the cheapest OEM Chinese weighs 10 grams thing, not that you'll use more than 400W max anyways, 300W should be typical.
PCPartPicker Part List: https://pcpartpicker.com/list/z3kQL2
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Amazon)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($79.99 @ Newegg)
Video Card: MSI Radeon RX 5700 8 GB Evoke OC Video Card  ($272.99 @ Newegg)
Total: $607.96
Generated by PCPartPicker 2020-03-17 20:52 EDT-0400
Maybe spend $8 more on this board for it's CPU-less USB bios flashing for recovery, also has a bigger VRM "heatsink"
https://pcpartpicker.com/product/9C97YJ/msi-b450m-gaming-plus-micro-atx-am4-motherboard-b450m-gaming-plus
MSI is supposed to have fixed or will fix any evoke memory temp issues, so there's that, as to why that 5700 is so cheap.
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/#findComment-13381225
Sell the old stuff
Total: $607.96
This is great, but I kinda forgot to mention in the previous paragraphs that the CPU is overclocked to 3.6GHz and I have a DeepCool Radiator* with a 1500 RPM Fan as cooling for the CPU, sorry again i was just reading through everything again
*heatsink, i meant heatsink, sorry again
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/#findComment-13381234
Just now, prolulz said:
This is great, but I kinda forgot to mention in the previous paragraphs that the CPU is overclocked to 3.6GHz and I have a DeepCool Radiator with a 1500 RPM Fan as cooling for the CPU, sorry again i was just reading through everything again
here's some CPU testing, I also edited the post a bunch
i have no idea why 2060 supers are $100 more expensive than some 5700s, the 5700s have the same performance.
The OC really won't matter too much since it's only a 4 core 4 thread CPU
Yours would just be a bit behind the 6600K here
There's also something to be said of frame consistency when you have more cores/threads to a point for background tasks.
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/#findComment-13381244
This is actually a lot more help than I was expecting, thanks for being nice and thorough, and actually bothering lmao. Will take everything into consideration, and thank you again for the help.
https://linustechtips.com/topic/1165826-help-me-choose-a-gpu/#findComment-13381254
