I have done quite a bit of research on keyboards but I am still confused with which one to buy. I've been using a rubber dome keyboard but wanted something better than the one I'm currently using that isnt too loud, So I started looking at MX red silents. I want a keyboard that comes with a wrist rest and liked the look of the razer ornata chroma but after research people don't seem to like it, I don't know if that's just because of the rubber domes or if there are other issues to hate on it. Any ideas would be greatly appreciated.
https://linustechtips.com/topic/1165825-help-with-keyboards/
K70, K95, G710 are my choices.
If you can suffer and get a 3rd party wrist rest, there's plenty more.
https://linustechtips.com/topic/1165825-help-with-keyboards/#findComment-13381167
Are there any real options other then the K70, razer keyboards or the Cooler master masterkeys? I don't like the font used on the k70 and don't like the textured spacebar, plus the lighting kinda looks cheap.
https://linustechtips.com/topic/1165825-help-with-keyboards/#findComment-13381175
Logitech has plenty.
If you're going to be extremely picky about it, build one
https://linustechtips.com/topic/1165825-help-with-keyboards/#findComment-13381181
