Hello,
I recently upgraded my RAM to a 2x 8gb 3600Mhz corsair vengeance RGB. Boot up and post is fine and my pc performance has greatly increased however about once a day my pc will either blue screen or shut down the game i am playing. This was not a problem before replacing my RAM. I have seen people suggest i reset the CMOS. What do you guys think?
Motherboard-B450F Strix
Ryzen 5 2600x
https://linustechtips.com/topic/1165381-i-need-help/
2 minutes ago, Callum purchese said:
Hello,
Ryzen 5 2600x
seeing you are on Ryzen, you may have to increase the Ram voltage slightly to make it a little more stable especially on high speed kits like this.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1165381-i-need-help/#findComment-13377098
Is you BIOS up to date? If so even the manual is showing a max speed of 3466 and that's not with the kit you have. If your part number is CMW16GX4M2Z3600C18 then it's not even listed. Which now a days doesn't exactly matter, but I'm sure the ram speed can cause a fuck up. Try dialing down your ram.
B450-F Gaming RAM QVL
https://linustechtips.com/topic/1165381-i-need-help/#findComment-13377122
I had this happen for a while. I went into the BIOS every boot and clicked revert to original settings and restart. I did that every day to make it have no issues and after a week it booted normally with no issues without the need to going into the BIOS.
https://linustechtips.com/topic/1165381-i-need-help/#findComment-13377555
