5 minutes ago, TheTwist said:
I am trying to share a few drives on some machines but i cannot get 1 UNC path to work.  Any troubleshoots i could try?
try using the IP instead of the hostname. For example, instead of \\DEVICE-NAME\share, try \\192.168.0.xxx\share or whatever the IP of your device is.
If that doesn't work, try pinging the device. If you can't ping it, you've got bigger networking issues.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1164600-unc-path-not-working/#findComment-13370878
Yeah IP address works.  I have a bit of software that uses UNC path.
https://linustechtips.com/topic/1164600-unc-path-not-working/#findComment-13370894
So that piece of software isn't accepting a specific UNC path? Even with just the IP?
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/1164600-unc-path-not-working/#findComment-13370931
28 minutes ago, TheTwist said:
IP works fine its just the UNC path that doesn't.  But i needs to be UNC.
So your router technically handles routing from a hostname to an internal IP. What are you using for routing? It should be done automatically.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/1164600-unc-path-not-working/#findComment-13371029
