Hello all,
My budget is £700 and it's main aim is for flight simming as well as it being a work computer. I also plan to play insurgency sandstorm and Rainbow Six Siege. I currently own two monitors, which I don't plan on upgrading:
One has a resolution on 1280x1024 (aspect ratio is 1.25:1) and connects via VGA. I'm currently using a VGA to DVI-I adapter.
Another that has a resolution of 1920x1080 (aspect ratio is 16:9) which uses either VGA or DVI-D.
OS is excluded from this list.
I plan for possible ugrades with this build in the future.
https://uk.pcpartpicker.com/user/Acerazus/saved/Lzrk6h
Any help for improvements or to save money would be greatly appreciated :)
Acer
https://linustechtips.com/topic/1164371-my-first-pc-for-flight-simming/
Fair build overall. However,
the 1660 super that you have selected doesn't have two DVI ports, and indeed almost every single graphics card you'll find will have a single DVI port at the very most. Do you plan on getting another adapter?
Primary PC:
PSU tier list
How many watts do I need?
As that's the case, then yes, I'll get another adapter
