To be clear, that's 8-pin EPS + another 4-pin EPS connector, not 12-pin.
Does your current PSU not have two EPS cables?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1164166-cpu-power-3950x/#findComment-13367266
55 minutes ago, Stoigeboiii said:
I know I have an 3950x do i need to go get a new powersupply with a 12 pin cpu power even if I don't plan to overclock?
the extra 4-pin is not needed unless you plan on doing LN2 overclocking.  there is no reason to swap PSU for the lack of a EPS connector
what PSU do you have?
https://linustechtips.com/topic/1164166-cpu-power-3950x/#findComment-13367288
54 minutes ago, Stoigeboiii said:
The motherboard has a 12 pin power connector
that is the cpu power. Your mtoherboard has 24pin connector. For that cpu atleast 8pin is needen and all the 12pins is suggested to have on for overlokcing or heavy usage.
That motherboard is not the best motherboard for your cpu. So you bought like 500+ dollar cpu and 200 dollar mobo?
You need a psu with 12 pin eps (cpu power or atleast 8pin or 2x4pin) and 24pin mobo power connector. Usually all 850w psu have them, some 750w might have them
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1164166-cpu-power-3950x/#findComment-13367289
no they arent.
you dont even get close to the rated throughput of a single 8-pin. which can deal with 384w. which is barely achievable during LN2 overclocking.
actually his board is more than fine for the 3950x.
its a slightly downgraded VRM from the 350$ strix board. and the VRM is really good for its price.
https://linustechtips.com/topic/1164166-cpu-power-3950x/#findComment-13367291
